1. AC Question's Avatar
    So i bought the Sennheiser cx 300 II, i plug them in my Samsung and the sound is really wierd like a distant sound, but when i put some force on it it works fine.
    Other headphones are working except this one.
    I tried the earbuds in several phones, in all the other phones it works.
    Does somebody know the problem?
    06-25-2014 08:24 AM
  2. srkmagnus's Avatar
    Perhaps you got a defective unit. First, I would make sure it's fully inserted (sometimes the jack can look and feel inserted, but may need that extra push). If it is and you are still having issues consider taking it back to the retailer or manufacturer for replacement.
    06-25-2014 10:10 AM
  1. Samsung S3 Factory Reset itself
    Last Post: 07-28-2014, 08:25 PM
  2. Samsung Fascinate OS upgrade
    By Len Griffin in forum Android 2.3 Gingerbread
    Last Post: 07-13-2014, 01:41 AM
  3. Galaxy Note Tab 10.1 2014 Problem
    By Azrine50 in forum Ask a Question
    Last Post: 06-27-2014, 01:23 AM
  4. samsung products quality
    Last Post: 06-26-2014, 01:30 AM
  5. Fix duplicate contacts problem in HTC devices
    By GuyTek in forum HTC One Series
    Last Post: 06-25-2014, 06:48 AM
