+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Default HELP! How do I turn LG phone on without sending pending text/
    I realized last second that I sent a text to the wrong person. It contains info I DO NOT want this person to know. I think I managed to turn off the phone before the text was sent. The last thing I saw before the phone went off was a message saying something like, "We were unable to send your message..." I am hoping there is some way to power up the phone in airplane mode and delete the text before it can be sent. Any ideas??
    --***** Texter
  2. #2
    Default Re: HELP! How do I turn LG phone on without sending pending text/
    Texts with that error message should need to be resubmitted. So far as I know the system does not try repeatedly to resend automatically after a failure.
  3. #3
    Are you sure? What if my LG phone automatically tries to send when I power up?
  4. #4
    I'm going to try making a Faraday cage. Then I will power up the phone, quickly switch it into airplane mode, and delete the text. Wish me luck!
  5. #5
    What carrier are you on.
  6. #6
    Okay, this is crazy, but I think it worked. I turned my washing machine into a Faraday cage by lining it with aluminum foil.(It might have worked without the foil, but why take chances?) I draped more foil over the door opening. I put a metal pot in the washer and had the lid handy. I turned the phone on, dropped it into the pot, and waited for it to boot up. I stuck my head and one arm through the foil drape, switched the phone to airplane mode, and pulled up the offending text. It was still trying to send; I could see the 'sending' message below the text message. I held the message down until the options appeared, selected [Delete] and waited for the text to disappear. It did. I left the phone in airplane mode for another 10 minutes, then switched to regular mode. I received a couple of texts, but nothing from the person who ought to have been outraged by the offensive and misdirected text. I tested the deletion of texts in airplane mode; none of the test texts were received by my test subject. I think it worked!
    Long story short: If you stupidly send a text to the wrong person, and realize it fast enough to turn off your phone or switch to airplane mode, you might get away with it. If I had instantly switched to airplane mode rather than turning off the phone the whole thing would have been a lot easier. I would not have needed the Faraday cage.
    This is probably the craziest thing I have ever done. (Well, okay, maybe not.) My first instinct was to smash the phone, but then I would not have known for sure if the text was sent. Plus I would need to buy a new phone. Then I considered powering up in an elevator or a cave. Too risky; how would I know for sure my phone wouldn't find the network? I got the idea for the Faraday cage from a Youtube video in which a guy demonstrated that Ed Snowden was wrong about phones not working in the refrigerator, but a phone in a cocktail shaker did not work due to the Faraday effect. Hence my foil-wrapped washing machine. I don't know if anyone will read this, but if you do, know that the Faraday cage really works.
    Many thanks to RumoredNow and ab304945 for your replies to my cry for help!
    -Bad Texter
  1. can't find the text mssg my phone says I have
    Last Post: 07-20-2016, 10:46 PM
  2. Will I be able to watch Google I/O Keynote on Chromecast?
    By StuMcBill in forum Google Chromecast
    Last Post: 06-27-2014, 06:08 PM
  3. How to create a textbox with multiple tappable links in android
    By Wasim Ansari1 in forum General Help and How To
    Last Post: 06-26-2014, 11:23 PM
  4. Help with SMS over Bluetooth not reading
    By bragz22 in forum LG G2
    Last Post: 06-25-2014, 10:34 AM
  5. Lg not going in recovery mod
    By agha_khubaib in forum LG G2
    Last Post: 06-25-2014, 09:41 AM
