Results 1 to 5 of 5
    Default Help! Droid Ultra on straight talk
    Hello everyone. I purchased a Droid Ultra and I read here and elsewhere it can be used on Straight talk prepaid with an ATT nano Sim. I ordered the ATT Sim from straight talk and inserted into the phone. When the phone boots up it says unknown Sim. I have not activated the Sim or set up a straight talk account yet. Does that have to be done for the phone to properly know what it is? I didn't want to waste money on a straight talk plan if it doesn't work.
  2. #2
    frag06's Avatar
    Posts
    Global Posts
    162 Global Posts
    Default Re: Help! Droid Ultra on straight talk
    Quote Originally Posted by darksylum View Post
    There are reports of it working and there are also reports that GSM U.S. SIM's are no longer recognized or supported. It may or may not work. You should call StraightTalk and ask them.
    If it does work, you won't have LTE. You would be able to get HSPA.
    It generally isn't a good idea to buy a CDMA phone when you are planning on using a GSM network.
    Quote Originally Posted by frag06 View Post
    Its not a big deal. I will have it working on GSM regardless. A local cellphone shop here in Portland has been pestering me to use an ATT prepaid service they sell and he guarantees it works on the ultra with there Sim. Straight talk is just a bit cheaper so I wanted to try that route since others have it working.
  4. #4
    I have the droid ultra on straight talk with at&t gsm & I get 4g lte...
  5. #5
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    "unknown Sim" could just mean that the phone is locked to another carrier. Are you sure it was being used on AT&T or that it's unlocked? (And that you don't have the radios set for CDMA and/or WCDMA only?)
  1. The Time on My Apps is Wrong
    Last Post: 12-29-2016, 12:28 AM
  2. Phone reboots on unmount SD card
    By asdfmn in forum General Help and How To
    Last Post: 03-01-2015, 10:59 AM
  3. Trouble finding files on LG G2
    By spb331 in forum Verizon LG G2
    Last Post: 06-25-2014, 11:46 PM
  4. Download Straight to SD Card?
    Last Post: 06-25-2014, 08:14 PM
  5. Please help!!!!!!!!!!!!!!!!!!!!!!!
    By iOstodroid79 in forum Ask a Question
    Last Post: 06-25-2014, 06:19 PM
