1. matt_perrin97's Avatar
    I was using my phone, listening to music, then it suddenly turned off and it wouldn't start. This has happened a number of times but the first few times i just took the battery out and used the power button then put the battery back in and it turned on. But this time i tried that and it didn't work so it tried putting it into recovery mode (power button, volume up button and home button) but that hasn't worked. Is there anything else that I can do?
    06-26-2014 06:11 AM
  2. Kelly Burby's Avatar
    hmm... that seems to be somewhat weird !! Well if you can't get yourself over the bootloader then I think you may need to go to the support for fixing it !!
    06-26-2014 06:32 AM
  1. Latest Gear Manager Update has serious problems ...
    By philmair in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 02-06-2016, 07:23 PM
  2. Replies: 1
    Last Post: 09-06-2014, 11:32 PM
  3. I need help fixing my Samsung Galaxy Ace II X
    By brookelamb in forum Samsung Galaxy Ace
    Last Post: 06-28-2014, 03:56 PM
  4. Samsung Galaxy s4
    Last Post: 06-26-2014, 06:56 AM
  5. Galaxy Tabs and Notes To Get Android "L" Release?
    By ColbyJvonBrown in forum Samsung Galaxy Tab 3
    Last Post: 06-26-2014, 05:23 AM
