1. AC Question's Avatar
    I connected my Nexus 5 phone to my laptop using the USB, but when i open My Computer, it shows the file is empty. What do I do?
    06-26-2014 11:33 PM
  2. Kelly Burby's Avatar
    Well, remove the USB from your Laptop, Switch your device off and then again power it on, try connecting it again over to your Laptop and when you are connecting you will get a option over you smartphone i.e connect it as MTP or as an camera select it as camera and then check if all the files are visible or not !! I am sure if all the drivers are installed then you can view the files stored over your device.
    06-27-2014 12:19 AM
  1. Multitasking on screen button problem
    By izzy67 in forum Moto G (2013)
    Last Post: 11-13-2014, 11:27 PM
  2. Fix my problem in samsung galaxy young gt-s6312
    Last Post: 08-31-2014, 11:52 PM
  3. turning on problem
    Last Post: 06-27-2014, 02:17 AM
  4. Problem downloading messages from iPhone users
    Last Post: 06-26-2014, 11:15 PM
  5. Nexus 5 dropping off the net work
    By somachand in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 06-26-2014, 10:14 PM
