1. AC Question's Avatar
    i have galaxy s4.. when making or receiving telephone call. i cant hear the dial tone ringing, when the recipient answers, they cant hear me & i cant hear them. same with head phones in. my speakers and mike work. tried battery out abd factory reset. any ideas for non tech person???
    06-28-2014 04:33 PM
  2. srkmagnus's Avatar
    Since you've already performed a factory reset I'm going to rule out a software problem and suggest that it might be hardware related. Has the device been dropped? Come into contact with water or moisture?
    It might be something internally that has gone bad, and the device may need to be sent for repair or replacement.
    06-28-2014 05:50 PM
  3. 70bigjay's Avatar
    thanks for the prompt reply.
    i have tested my phone with *#0*#
    my speakers and mike work, also the receiver works, infact all the tests came back with pass, so i am bamboozled...
    06-29-2014 02:21 AM
  4. 70bigjay's Avatar
    RESULT!!!!!!!
    spoke with orange, jumped through all the hoops to test the phone
    thankfully its still under warranty, so a new one being delivered in the morning!!!!!!
    06-30-2014 03:40 PM
  5. Gary Smith13's Avatar
    It could be the blue tooth. Have you paired your phone with anything recently? My wife and I just got new Galaxy s5, after pairing with car's hands free we lost ability to hear except when on spearphone. I turned off bluetooth on both phones (you just need to do yours) and turned the phone off. Upon powering back on, we could hear again, even when switching blue tooth back on. Hope that helps
    08-10-2014 10:17 PM
  6. Gary Smith13's Avatar
    It's probably the bluetooth pair. Turn off bluetooth on your phone, then turn off the phone. Turn back on and it should work. Should also work after turning bluetooth back on.
    08-10-2014 10:18 PM
  7. jza95's Avatar
    It's a Google Now update that screwed up. The Ok Google search from any screen is turned on by default. From the home screen, hold down the menu button which should go into Google Now. Click on menu button again and select settings. Select "VOICE." Then select "Ok Google" detection. Once there, switch off the option "From any Screen." Once that is turned off. Restart phone and everything should work fine.
    01-21-2015 08:22 PM
  1. Have they added call blocking to L?
    By worknman in forum Android 5.0 Lollipop
    Last Post: 03-04-2015, 05:18 AM
  2. The ATT 2yr contract for Fire phone is a SCAM!
    By John Chen2 in forum Amazon Fire Phone
    Last Post: 11-05-2014, 01:41 AM
  3. Replies: 3
    Last Post: 07-20-2014, 01:06 PM
  4. Replies: 10
    Last Post: 06-29-2014, 09:35 PM
  5. Camera shortcut is no such thing
    Last Post: 06-28-2014, 04:21 PM
