1. AC Question's Avatar
    I have been using my galaxy s3 for 1 year now and my battery is acting weird. When i charge it it takes too much time( i let it over night and get to 45%). when i unplug it it says 100% then 1 hour later goes to 45%, do you think my charger is the problem or the battery? It takes too much time to charge, thanks!
    06-28-2014 06:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sounds like the battery. A quick test is to remove it, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is bad. But even if it doesn't spin, it's worth trying a new battery.
    dancing-bass likes this.
    06-28-2014 08:01 PM
  3. Fliint's Avatar
    When i plug it to my computer it charges quicker. Maybe its a problem with the a/c adapter?
    06-29-2014 12:57 AM
  4. B. Diddy's Avatar
    That is odd--the computer usually charges slower than the wall outlet. So you may be right--it could be the charging plug. Do you have another one you could connect with the USB cable?
    06-29-2014 01:24 AM
  1. virgin media super hub problems
    By Kieran Storer in forum Moto G (2013)
    Last Post: 07-02-2014, 04:00 PM
  2. galaxy s3
    By johnnie 65 in forum General Help and How To
    Last Post: 06-30-2014, 11:28 AM
  3. Home button wake up on Galaxy S5
    By glasblowa in forum Ask a Question
    Last Post: 06-28-2014, 07:10 PM
  4. Constant Reboot on Samsung Galaxy S3
    Last Post: 06-28-2014, 06:13 PM
  5. Samsung S4 won't turn on
    Last Post: 06-28-2014, 06:08 PM
