A
AC Question
Hi All,
I have a Galaxy Note 10.1 (2014 Edition) SM-P605 and it works fine when you start it. however, when you unlock the screen after a timeout or when locking it with the power button, then everything is pink (e.g lock screen, icons, etc) and the background is greenish instead of blur.
It is like the screen has reverted to 256 colours.
I have done a factory reset and reinstalled the firmware using Kies, but no luck and Samsung's support is no help.
It has to be a software issue, since it works perfectly until the screen is locked (currently have the screen timeout set to 30 minutes).
Cheers.
Cheers.
