1. Loriel Santos's Avatar
    Hello I'm new here but can you pls help me I have a problem with my phone screen my phone screen is wet like smooth but I have no dropped itinto water or the water was not dropped to it its an android phone iI have tried drying it with my cloth but it comes back t wet like smooth screen again pls help me
    06-29-2014 04:29 PM
  2. RumoredNow's Avatar
    What kind of phone? Do you know if it has an Oleophobic coating on the screen. That kind lets the oil from your fingers build up and slide around on the surface. Kind of hard to clean off.
    I use a soft, lint free cloth like the kind that comes with screen protectors to clean my screens. You can try breathing heavily on the screen to "fog" it and then wiping with the cloth. It usually helps the oils wipe away better.
    06-29-2014 05:08 PM
  3. STARGATE's Avatar
    Also, do you take the phone into the bathroom while you take a shower?
    Lets say you left the phone on the sink or somewhere inside the bathroom.
    Some phones do get like that with the steam from the shower.
    Sent From Another Galaxy
    RumoredNow likes this.
    06-29-2014 05:20 PM
  4. Loriel Santos's Avatar
    Its a starmobile phone from the philippines no im just 12 years old i dont know any oleophobic thing in my phone
    06-30-2014 07:33 AM
  5. msndrstood's Avatar
    Does anyone else in your household have this problem? It could be humidity. Just a thought.
    Golfdriver97 likes this.
    06-30-2014 08:38 AM
  6. Golfdriver97's Avatar
    msndrstood might be onto something here. If the screen wasn't sealed off properly, then condensation might be getting underneath the screen. Similar to double pane glass windows and water vapor gets in between them.
    msndrstood likes this.
    06-30-2014 09:28 AM
  1. Groups contact list will not send in Gmail
    Last Post: 09-04-2014, 12:22 AM
  2. problems after installing new screen/digitizer nexus 7 2012
    Last Post: 08-08-2014, 10:16 PM
  3. Screen Modifier
    By lambrewsk64 in forum Ask a Question
    Last Post: 06-29-2014, 04:21 PM
  4. problems with s3 mini
    By HiryuXIII in forum Samsung Galaxy S3 Mini
    Last Post: 06-29-2014, 04:08 PM
