+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Nexus 7 battery
    where can I go to have my battery replaced? My tablet will not come on even after holding power/volume control down. My computer can't see it when it is connected. My tablet did an update and then stopped working. If I replaced the battery will it happen again, or should I just another tablet? Thanks
  2. #2
    RumoredNow's Avatar
    Posts
    Global Posts
    20,235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 7 battery
    Was the battery fine before the update?
    The tablet stopped working right after the update? Did it ever boot up and work even once after the update was applied?
  1. Battery Doctor behaviour change
    Last Post: 08-26-2014, 11:02 PM
  2. problems after installing new screen/digitizer nexus 7 2012
    Last Post: 08-08-2014, 11:16 PM
  3. Best way to tell what is causing battery drain?
    By Bamafan501 in forum Samsung Galaxy S3
    Last Post: 06-30-2014, 02:35 PM
  4. Low Battery Mode
    By Nixon1154 in forum Sony Xperia Z2
    Last Post: 06-29-2014, 08:10 PM
  5. Galaxy Tab 3 OR Nexus 7 2012?
    By ColbyJvonBrown in forum Samsung Galaxy Tab 3
    Last Post: 06-29-2014, 04:16 PM
