1. normy baroro's Avatar
    My camera is not working and unfortunately gallery has stoo
    06-30-2014 03:22 AM
  2. Kelly Burby's Avatar
    Well, there are two things first is you haven't mentioned any information about your device and secondly what I am going to suggest you is try going to the application manager>select the camera application> clear its cache and data store. Now again try opening the camera application it should start working fine. But If you still feel that camera is not working then think for a time and remove any recent application you have installed which is interfering with the normal working of the camera i.e. start removing all the third party camera apps. Next if that still doesn't helps its recommended first to perform a soft reset and then to full factory resetting your device. But if again you encounter some issue I am afrid but you may need to walk towards the nearest store for fixing it up !!
    06-30-2014 03:59 AM
  1. Kitkat 4.4.4 problems with Contacts
    Last Post: 11-13-2014, 01:17 PM
  2. 2 questions about camera
    By luv4u859 in forum Samsung Galaxy S5
    Last Post: 07-01-2014, 08:52 PM
  3. down loading problem
    Last Post: 06-30-2014, 06:47 AM
  4. Problems playing music
    By rachm10 in forum HTC One M8
    Last Post: 06-30-2014, 04:11 AM
  5. Sync is currently experiencing problems
    Last Post: 06-30-2014, 02:05 AM
