1. AC Question's Avatar
    Ok so my Nexus 4 started acting funny last night. I plugged in the charger and the charging icon appeared then disappeared. I moved the charger usb around and it would come on and off. I know for a fact that it isnt the port because when i plug it into the computer, it can read it but it wont charge? Also my phone says it has 40% battery life but sometimes it will say it has 2% and shuts off. Without even charging it i can turn it back on and it will say 40% again. Oh and i cant turn it on regularly. I have to hold down the volume key and power button and click start to turn it on. If i try to turn it on normally, it would vibrate for a quick sec like it is going to turn on but it doesnt. If i hold on the power button, it will continue to vibrate on and off three times before being completely unresponsive. Please help
    06-30-2014 02:33 PM
  2. zocster's Avatar
    Have you tried a factory reset? Reload your ROM?
    Sent from pin:2AD743B7 via Tapatalk Pro
    06-30-2014 02:36 PM
  3. RDroid21's Avatar
    No I havent. My Nexus 4 is rooted and unlocked. If i do a factory reset, will i lose the unlock and root abilities?
    06-30-2014 02:44 PM
  4. zocster's Avatar
    Nope, you'll be fine
    06-30-2014 02:48 PM
  5. RDroid21's Avatar
    I did a factory reset. It did not fix my issue. Any other ideas?
    06-30-2014 03:34 PM
  6. zocster's Avatar
    Not sure if you had tried reloading the ROM? Sounds like the battery not holding charge? Which model is this?
    06-30-2014 04:00 PM
  7. RDroid21's Avatar
    Im not sure how to reload the rom.
    its a Nexus 4 but on the screen when you hold on to the volume and power key, it says under product name and variant: Mako 16GB
    Nesux\
    06-30-2014 04:12 PM
  1. Replies: 1
    Last Post: 01-03-2015, 11:16 AM
  2. HTC ONE issues after 4.4 update - No sound on just the video
    Last Post: 07-17-2014, 12:50 AM
  3. Keeping Unlimited Data on Verizon - Switching from a SIM to a Micro SIM
    By Kaiser Droid in forum General Android Device Chat
    Last Post: 07-07-2014, 09:31 PM
  4. Possible to install Android on Acer C720P Chromebook?
    Last Post: 07-01-2014, 06:09 PM
  5. Replies: 3
    Last Post: 06-30-2014, 03:56 PM
