1. AC Question's Avatar
    Hi there, I just got my Samsung Galaxy ace 2x in april and it worked perfect. But on thrusday my phone wouldn't send any text messages, it would say "Message not sent". So I thought my phone was locked because I went over my plane and it was so I unlocked it... but it still isn't working. im not sure if this is normal or if it isn't.. so someone please help!!!!!!!!
    06-30-2014 10:14 PM
  2. Kelly Burby's Avatar
    Well, firstly try clearing the cache and the data of the messaging application and see if that works for you or not ! If it started working then its well and good other wise open the messaging settings>tap on the message centre and see if there is any number written over it ?? if you find the number than its good otherwise give a call to your operator support and ask him the number of the message centre and put it manually over the .... !!
    Let me know if that fix your problem !
    07-01-2014 02:01 AM
  1. Odin says "PASS" but root checker says "not rooted" Help!
    By Beverly Blaze in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 02-16-2015, 02:53 AM
  2. GalaxyS3 Internet Problems?
    Last Post: 07-09-2014, 09:48 PM
  3. Replies: 1
    Last Post: 07-09-2014, 09:47 PM
  4. Viber problem after kitkat update
    By 3m1100 in forum LG G2
    Last Post: 07-02-2014, 01:42 PM
  5. Replies: 1
    Last Post: 06-30-2014, 10:25 PM
