+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Default Please help Camera settings
    Hi, I have Samsung galaxy S5 and the model is SM-G900T. I dont have camera settings on my phone. When you click on the camera there is suppose to be a gear shaped icon and its not there, therefore I can't use any camera features. Can some please help.
    Thank you
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Please help Camera settings
    When you go into the camera app, can you tap and hold the recents button to access the options menu? Maybe there will be a settings option there.
    If that doesn't work, go into your apps and find the camera app. Select it and then clear the cache for the app.
    Sent from my Galaxy S4 running SOKP 4.4.2
  3. #3
    Bushra Bushra's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    recents button? like the recent picures?
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Bushra Bushra View Post
    The button on the left of the home button. It normally shows your recent apps, but I believe long pressing will show the menu.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone was in easy mode and after i switched it to standard mode, the settings button was there...
    thanks for your help though!
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Ah. Yeah, that would do it. Glad you got it working
  1. Camera remembers mode on launch
    By Jaggrey in forum HTC One M8
    Last Post: 07-03-2014, 02:58 PM
  2. Replies: 0
    Last Post: 07-01-2014, 03:32 PM
  3. my phone has deleted apps and settings
    Last Post: 07-01-2014, 02:54 PM
  4. Settings protection
    By David Crenshaw in forum Samsung Galaxy S4
    Last Post: 07-01-2014, 02:25 PM
  5. Zelda.????? Help me.
    Last Post: 07-01-2014, 02:19 PM
