1. DONALD D JOHNSON's Avatar
    If i remove the battery in my galaxy s4 will i lose all my information?
    07-02-2014 01:56 PM
  2. UJ95x's Avatar
    Nope. You can take out the battery and replace it with another. Just make sure it's off when you do it.
    dpham00 likes this.
    07-02-2014 01:57 PM
  3. dpham00's Avatar
    I have taken my battery out many times, and haven't lost any data
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    07-02-2014 02:50 PM
  4. jamespark7's Avatar
    nope~ you can remove the battery as much as you wish and your information will be there.
    Removing battery will only turn off your device and nothing else.
    07-02-2014 06:20 PM
  5. DONALD D JOHNSON's Avatar
    Thank you all
    07-03-2014 10:31 AM
  1. Nexus 7 (2012) Crashing, shutting down and battery drain
    By se99paj in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-11-2014, 03:19 PM
  2. high phone usage in battery but I made no calls
    By specs34 in forum Samsung Galaxy S5
    Last Post: 07-04-2014, 04:46 AM
  3. Replies: 1
    Last Post: 07-02-2014, 02:56 PM
  4. galaxy s5 "phone" using too much battery
    By specs34 in forum Ask a Question
    Last Post: 07-02-2014, 01:11 PM
  5. Galaxy S4 Batteries
    Last Post: 07-02-2014, 12:59 PM
