+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default NEXUS 4 - Booting to Safe Mode, won't toggle between boot options, numerous issues.
    I need serious help. A bunch of issues going on... My Nexus 4 continues to boot to Safe Mode, volume will just automatically reduce to vibrate (almost like stuck, but not), have to hold power button for 10 secs to reset, sometimes can press power button then power off, but then won't allow me to click ok.
    What happened... had speaker facing out / screen against body during work out (wasn't thinking about sweat). Wiped dry afterwards. Seemed work fine, except screen a little finicky as expected. Few minutes later, it wouldn't turn on or anything. Finally with black screen, pressed volume up and got a beep as volume maxed, but no screen image.
    Toying with it, finally got it to boot, but booted to the Fastboot screen with Android laying down, options below, Start / Power Off / Restart bootloader / Recovery Mode flashing on top. The volume controls won't toggle to any of the options, does nothing. Pressing power button sometimes boots it to Safe Mode, other times to the Droid laying with no command text.
    Getting it back into Normal Mode is the biggest issue. Can deal with the rest for the most part. Help!
    FYI, stock phone not rooted or anything. Got it used off ebay 10 months ago as replacement. No issues at all until this. Running 4.4.
  2. #2
    RumoredNow's Avatar
    Posts
    Global Posts
    20,269 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: NEXUS 4 - Booting to Safe Mode, won't toggle between boot options, numerous issues.
    If you truly suspect moisture, try submersing the phone in rice (powered off) for 24 - 48 hours.
    However, the salts from sweat make the issue more uncertain as they have a corrosive effect. You could seek qualified repair.
  1. Galaxy S5 Car mode
    Last Post: 09-23-2015, 10:04 AM
  2. Lag when moving phone away from face to hangup call
    By Kevin Schultz1 in forum Samsung Galaxy S5
    Last Post: 05-17-2015, 02:15 PM
  3. data transfer (droid maxx to droid maxx - Verizon)
    By poppapico69 in forum Ask a Question
    Last Post: 09-01-2014, 07:51 PM
  4. New to the site and to Android, What Apps I CAN or CAN'T Remove
    By cdscycleandatv in forum Samsung Galaxy S4
    Last Post: 07-12-2014, 01:04 PM
  5. mailer - URL issue
    By hideki ashida in forum Google Nexus 7 Tablet (2013)
    Last Post: 07-03-2014, 09:53 PM
