A
AC Question
Ok so yesterday I had my nexus 4 in the charger at 46 percent and i was about to send a tweet when the screen froze. thinking it was a simple crash i pressed the home button and no visual response then it powered off. now whenever i try to power it on nothing happens. i tried pressing the power and volume buttons. whenever i try to turn it on and i plug it in the red light flashes. sometimes it flashes continiously sometimes it is a solid color. so what can i do it wont communicate with the computer. im not sure what the issue is. is it a battery issue or is it impossibly bricked. i already charged it overnight to no avail.
oh and im running stock cm11 with the stock cm kernel. i just installed it the night before.
