1. AC Question's Avatar
    first i have xperia mini St15i
    i want to upgrade it to cm 10
    i install the rom and everything good
    but when i restart the device it still gie me sony logo , then i change the kernel
    after this the device show me sony logo then it's gone and appear cm 10 logo
    and it's still circling for ever
    i dont know witch kernel i have to flash to work
    can you help me
    07-05-2014 09:06 AM
  2. Paul627g's Avatar
    Hard call to make without having the device but getting down to basics.
    If the version of CM your flashing is SPECIFICALLY built for your exact version of device (region/carrier) then it should boot and work fine per CM's instructions if its an official build by the CM maintainers. If your flashing a build that isn't done by the official CM maintainers then your basically rolling the dice and hoping that whoever compiled and built the ROM and kernel package has done it correctly for your specific make of device.
    07-05-2014 09:11 AM
  3. Sh98arif's Avatar
    thanks for your fast reply , i instal a cm 10 for my device from here
    https://sites.google.com/site/projec...yanogen-mod-10
    my device in the supported devices
    07-05-2014 09:25 AM
  4. Sh98arif's Avatar
    07-05-2014 09:27 AM
  5. Sh98arif's Avatar
    i'm the man who write the question , i registered in the fourm
    07-05-2014 09:29 AM
  6. Sh98arif's Avatar
    any one help please
    07-05-2014 09:49 AM
  7. Sh98arif's Avatar
    any help ?
    07-05-2014 10:47 AM
  8. Paul627g's Avatar
    I would check with CM's site and see if they have an official build for your device. They might offer more details and/or something that you could be missing to get it booting.
    CyanogenMod Downloads
    07-05-2014 01:12 PM
  9. Sh98arif's Avatar
    i solved the problem , i wipe every thing then i reinstall the cm 10 and flash
    (3.4.45-nAa-03_ST15) kernel
    and it's work perfect thanks for allah
    07-05-2014 06:05 PM
  10. Paul627g's Avatar
    Glad to hear it.
    07-05-2014 07:24 PM
  1. add a shortcut with combination of hardware buttons
    By theimmortalbg in forum Ask a Question
    Last Post: 09-02-2014, 01:40 AM
  2. Youtube video results in freeze and restart
    By Rivercreature in forum ASUS MeMO Pad 10
    Last Post: 07-13-2014, 09:08 PM
  3. An APP to combine/unify TEXTS and BBM messages?
    By ShaneN. in forum Android 4.4 KitKat
    Last Post: 07-06-2014, 02:53 AM
  4. Replies: 0
    Last Post: 07-05-2014, 08:35 AM
