1. StardustGalaxy's Avatar
    Sims freeplay or something left behind from it is still running when I look in my battery log. It is running as "com.ea.games. simsfreeplay_na" I tap on it and the force stop and report buttons are grayed out. Also package a cess helper is running, both at 29% of my battery. Drained my phone over night and when I woke up my phone was very hot. How do I fix this?
    07-05-2014 09:15 AM
  2. Paul627g's Avatar
    Have you rebooted the phone since uninstalling Sims? Someone else may have a better option to weed out what exactly is left behind and remove it but on the other hand it might come down to doing a factory reset to clean out whatever it is that was left behind.
    You could also try booting into your recovery and wiping cache and see if that helps.
    07-05-2014 09:18 AM
  3. StardustGalaxy's Avatar
    Yes I tried restarting, and also completely tuning off my phone and removing the battery. It's still there.
    07-05-2014 10:09 AM
  4. peacefulberry's Avatar
    Not just a restart but a soft reset. Normally that's holding the power button in until the phone restarts like 15 seconds or so. Also, is the app still listed in your app list on your phone?
    07-05-2014 01:16 PM
  5. dannyhamilton12's Avatar
    Hello has anyone found a solution to this problem yet I have the same phone have done the same thing and have the same problem only had the phone 4 days and I thought my battery was faulty then I realised this is what was draining massive amounts of battery Cheers Danny
    08-23-2014 12:20 AM
  6. Karl Efdzan's Avatar
    Yup guyz...just install back the game and open the game in setting > general > application manager > sims freeplay, then you should 'clear cache' and 'stop force' from there. After that, please 'uninstall' the game. Wait for a while until the process is complete. Then restart your HP and open setting > general > battery, you should seen the process for ea.sims..bla..bla.. is gone. Good luck.
    09-10-2014 10:42 PM
  1. An APP to combine/unify TEXTS and BBM messages?
    By ShaneN. in forum Android 4.4 KitKat
    Last Post: 07-06-2014, 02:53 AM
  2. problem with kernel and cyanogenMod
    Last Post: 07-05-2014, 07:24 PM
  3. NeeD HelP FoR MY GalaxY GranD !!!!
    Last Post: 07-05-2014, 09:40 AM
  4. Replies: 0
    Last Post: 07-05-2014, 08:35 AM
  5. Swipe ME - Android Game
    By Shaik Sadiq in forum Android Games
    Last Post: 07-05-2014, 08:14 AM
