+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Unhappy Help. my s4 stuck on half way of rooting. I think i its dead
    i got s4 from t mobile. the problem started 1 month ago which is (not registered into network). from the start it was easy to solve i just restart it then everything is alright. but know i tried everything from the internet until i found a website says you most root your phone then you instal some files. so i wanted to root my phone by odine while the phone is transferring the files required for rooting it get stuck for half an hour so i turned my phone off and decided to do it again. then i tried to turn on the phone but it want restart normally. it says go to the recovery mood by kise which i did so but it did not work. please help me.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,672 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Help. my s4 stuck on half way of rooting. I think i its dead
    You might need to reflash the stock ROM with a PC program called Odin. After you are up and running you can try the root procedure again.
  1. Unable to Play Video (MP4 file) on Kindle Fire
    Last Post: 03-04-2015, 12:55 AM
  2. Pend drive for non rooted Nexus 7 2013
    By Sat Maya in forum Google Nexus 7 (2013) Accessories
    Last Post: 08-22-2014, 01:23 PM
  3. Samsung Galaxy Nexus Won't Turn On
    By DelRoba in forum Google / Samsung Galaxy Nexus
    Last Post: 07-06-2014, 10:01 AM
  4. After reboot Samsung S3 i cant use my phone
    By littleroad in forum Ask a Question
    Last Post: 07-06-2014, 09:44 AM
  5. rooting help moto g
    Last Post: 07-06-2014, 09:31 AM
