1. burnowt00's Avatar
    Trying to insert screen shot to show my battery drain. Can anyone help a noob out?
    07-07-2014 03:56 PM
  2. belodion's Avatar
    07-07-2014 04:26 PM
  3. anon8380037's Avatar
    To post from the Android Central app touch the attachment / paper clip icon and you can select gallery or photos and chose the screenshot. Tapatalk or the AC Forums app have access from the 3 button overflow symbol upper right. Depending on your make of phone I guess.
    07-07-2014 04:33 PM
  4. burnowt00's Avatar
    So I need to download the app? Going through the website on my phone doesn't have any attachments option
    07-07-2014 05:12 PM
  5. burnowt00's Avatar
    Now all three of the androids are showing even higher. Android is is up to 35 percent
    Sent from my SGH-M919 using AC Forums mobile app
    07-07-2014 05:21 PM
  6. burnowt00's Avatar
    *OS
    07-07-2014 05:22 PM
  7. belodion's Avatar
    Your screenshot figures look okay to me but if you're saying Android OS is getting dramatically worse...has happened to me...power down the phone for a minute or two then switch back on. By power down I mean long press on the on/off button till the power off or power down option comes up.
    07-07-2014 05:39 PM
  8. burnowt00's Avatar
    Here's another
    07-07-2014 06:12 PM
  9. belodion's Avatar
    About 2¼ hours after the first. Yes, something not right. In my case, Android OS and Wifi (which Google can use on my phone) were responsible. I powered down, then back on, and at that point in the battery graph you could see where it had stopped the Wifi dead, and I suppose Android OS working in tandem with it. Thereafter, battery use restored to normal.
    07-07-2014 06:32 PM
  10. anon8380037's Avatar
    What are you concerned about exactly? Is the phone new to you, or did you have better life before.
    Android OS seems in the high but normal range. I am coming from a Note 3 but it's not too different.
    If you can get 14 - 20 hours from 100%, but more importantly 4 - 5+ screen time without topping up you are doing fine. S4 owners correct me though.
    It's more informative to also post the battery history details by touching the graph area in that screen, and the screen time by touching the 'screen' percentage, see below.
    The GSam app will give you more detail again.
    If you recently updated to KitKat, Android OS gets high for a while and syncing gets out of whack!
    Ignore any details on mine as I started charging 90 minutes ago, or they are old GSam shots.
    (@Belodion I will get back to you tomorrow with apps. I was watching the 'Tour' and ran out of battery! before a train home.)
    Sent from my SM-N9005 using Tapatalk Pro
    07-07-2014 06:54 PM
  11. burnowt00's Avatar
    My battery only gets about 8-10 hours before it needs to be charged again
    07-07-2014 06:58 PM
  12. anon8380037's Avatar
    My 3200 mah battery can drop drastically if I use about 2-3 hrs almost continuous screen time in the afternoon just browsing and posting, so I often get less than 8 - 10 hours. I got 2 days over a weekend recently with low screen time.
    There are always some things you can do to improve life though. I don't know how long you've been on Android or the S4.
    Welcome to Android Central btw.
    Maybe head to the S4 main forum, or for your carrier, and search recent battery threads.
    I had a long day in London but you can still get more help here. Perhaps tomorrow.
    07-07-2014 07:15 PM
  13. belodion's Avatar
    burnowt00: Did you try the soft reset?
    Madd54: Get some rest and don't worry about the apps.
    07-08-2014 01:30 PM
  14. burnowt00's Avatar
    I did a factory reset. Still not great but better
    08-14-2014 10:38 PM
  15. belodion's Avatar
    We shan't be satisfied until you are. Could you post another battery usage screenshot after a few hours from charging, as well as give an idea of what you used the phone for during that time?
    08-15-2014 06:42 AM
  16. burnowt00's Avatar
    Ok I will post tonight
    08-15-2014 11:40 AM
  1. Samsung S4 Mini picture date stamp
    Last Post: 09-24-2016, 05:47 AM
  2. Battery life really THAT bad?
    By FaintDeftone in forum Samsung Gear Live
    Last Post: 10-17-2014, 05:22 PM
  3. Replies: 1
    Last Post: 09-04-2014, 12:55 AM
  4. Samsung S4 Mini Unable to Detect SD Card Reader
    Last Post: 09-02-2014, 01:57 AM
  5. Weird battery problem
    By androidgirl3107 in forum Samsung Galaxy SIII I9300
    Last Post: 07-07-2014, 10:11 PM
