+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Unhappy Battery drain
    dear,sir/madame
    My name is Alex and Recently, i am experienceing battery drain so fast. i bought another battery to make sure. But still no change at all.
    When the battery percent reaches 30% in 2 seconds it will be 15%. after it reaches 15%, every 3 second it drains 1% of battery.
    My phone is Samsung Grand DUOS
    i didnt do any update or what so ever. i try to put my brightness down, turn off mobile data,WIFI,location service etc. But still no change of the Drainage problem. should i Reset my Phone? or any other way?
    Please help me solve this problem, i would appreciate it
  2. #2
    Default Re: Battery drain
    Welcome to Android Central! First thing to try is to unmount your external microSD card (in Settings>Storage), removing it, and rebooting. If there's a corrupt file on the SD card, or the card itself is corrupt, that can cause significant battery drain (often due to the Media Scanner getting hung up on the corrupt file).
    If that doesn't help, then try booting into Recovery Mode and wiping the system cache partition, which won't erase any personal data. Follow the steps in this video, but at around 1:15, make sure you select Wipe Cache Partition instead of Wipe Data/Factory Reset. Then select Reboot System Now.
  1. 10,000 mAh battery needs to be standard in smart phones
    By datum9 in forum General News & Discussion
    Last Post: 12-25-2014, 06:45 PM
  2. Battery life really THAT bad?
    By FaintDeftone in forum Samsung Gear Live
    Last Post: 10-17-2014, 06:22 PM
  3. s4 battery drain
    By burnowt00 in forum Ask a Question
    Last Post: 08-15-2014, 12:40 PM
  4. Weird battery problem
    By androidgirl3107 in forum Samsung Galaxy S3 I9300
    Last Post: 07-07-2014, 11:11 PM
  5. 4.2.2 OS using too much battery?
    By classic20 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-07-2014, 08:21 PM
