1. AC Question's Avatar
    So, after messing with different boot animations for a while, I discovered that the power button will no longer put my Note 3 to sleep. The power button functions normally on a long press, giving me the Power Off/Restart options, as well as turns the phone back on. I tried putting all the original files back in the media folder, but the problem persists.
    Anyone else have this issue before? It's starting to drive me a little crazy.
    Thank you!
    07-08-2014 06:15 AM
  2. Golfdriver97's Avatar
    The only way I can think of to fix it is to reflash a stock ROM with Odin.
    07-08-2014 08:42 AM
  3. Douglas Kerr's Avatar
    hi guys same thing just happened to me, any chance the stock flash fixed the problem???
    07-23-2014 01:27 AM
  1. Replies: 1
    Last Post: 08-25-2014, 04:51 PM
  2. how to remove carrier boot screens
    By Sean Fanelli in forum HTC One M8
    Last Post: 07-08-2014, 06:34 PM
  3. Playstore wont work, galaxy tab 3
    By Unregistered in forum Ask a Question
    Last Post: 07-08-2014, 08:44 AM
  4. My phone wont ring
    Last Post: 07-08-2014, 05:49 AM
