+ Reply
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By SpookDroid
    AC Question
    AC Question's Avatar
    Guest
    Default Battery Issue / Once battery down to 46%...goes in to reboot and constant loop.
    Samsung Galaxy Note Pro 12.2. Once the battery gets down to around 46% remaining, the unit tries to restart on it's own. Then it goes into a constant loop and will not come up unless I plug it into a power source. Not happy with recharging......It is noticeable that there are times the battery seems to charge and other times something happened (over night) that it didn't fully charge.
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Issue / Once battery down to 46%...goes in to reboot and constant loop.
    This is definitely not standard behavior. You can try 'recalibrating' your battery by letting the tablet run out of juice entirely, charge to 100%, and then let it drain completely again. However, restarting itself at 46% is not a good sign and I'm not too hopeful that the battery recalibration might help, but it's worth a try.
    IMHO, you should take this unit for Warranty exchange.
    Golfdriver97 likes this.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,086 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    I am guessing something is up with the battery as well. I would call Samsung about it. Especially if you are still under warranty. Get the ball rolling as soon as possible.
  1. Replies: 1
    Last Post: 08-25-2014, 05:51 PM
  2. Power Button working, but will not put phone to sleep?
    Last Post: 07-23-2014, 02:27 AM
  3. how to remove carrier boot screens
    By Sean Fanelli in forum HTC One M8
    Last Post: 07-08-2014, 07:34 PM
  4. Home tab disappeared in Chrome
    By walhalla in forum Ask a Question
    Last Post: 07-08-2014, 09:51 AM
  5. Home button disappeared in Chrome
    Last Post: 07-08-2014, 09:50 AM
