+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default galaxy s3 screen wont turn on, then after taking battery out, phone will not turn on
    after taking my phone off the charger, I see that it is on because the little blue light is blinking like I have a message, but when I push the side button the screen wont turn on. I take the battery out thinking I can just restart it. the phone will not turn on at all now.
  2. #2
    Default Re: galaxy s3 screen wont turn on, then after taking battery out, phone will not turn on
    Welcome to Android Central! Take the battery out, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which suggests a failing battery. Try a new battery.
    Also, have you tried pressing and holding the Power button down for 15 seconds or so?
  1. Replies: 2
    Last Post: 10-13-2014, 11:46 PM
  2. how to connect computer to cell phone
    Last Post: 07-08-2014, 02:12 PM
  3. Finding used Samsung Galaxy
    Last Post: 07-08-2014, 10:18 AM
  4. Samsung galaxy s5
    Last Post: 07-08-2014, 10:06 AM
