Gear Live / Multiple Issues - Questions
idealmuzik
3
1. Can read multiple gmail emails, but not from S5 stock email app connected to MS Outlook Exchange, when multiple emails come in, they show up as one notification, can not click on each email and read. (Please help, advise) Why doesn't all incoming email show individually so each can be read. ie in gmail there is a bar at the bottom that will say +3, +4 etc, which you can click on and see each message individually
2. Battery is the worst, below 20% by afternoon ( screen brightness set to 3, only few notifications coming through)
3. Still can not get Runtastic Pro to work. I can open it with voice command, but can not start or monitor a session, cards are not opening when the application is running.
4. Music Player Controls: the pause, skip fwd, and skip back are each on a separate screen (really? what genious designed this?)
5. No app launcher, everything has to be done with voice. So what if you're at a restaurant or in a meeting. There should be options.
This device / software has a long way to go, any tips or advice on this?
akbarramadhani12
