1. AC Question's Avatar
    Hi guys , i am using Moto G, the phone was incredibly fast and smooth ,,. but on some time it says ,, "play tone" and it will disappear ,, i thought it is volume problem .. but actually it is not , please help me ,, the "play tone " , comes and gone,, why it was coming like that ,, please tell me
    - jimklay
    07-09-2014 08:52 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sounds like it's related to some app you may have installed. It can be hard to pinpoint which one, though. Try uninstalling some of your apps, starting with the most recently installed.
    07-09-2014 01:03 PM
  3. jimklay's Avatar
    hi , thank you , in my phone it was coming intially one or 2 weeks when i bought the phone , i have tried uninstalled the unnecessary files ,, my question is whether it is software problem or hardware problems ?? please help me
    07-12-2014 03:59 AM
  4. B. Diddy's Avatar
    When you say that it says "play tone," do you mean a window pops up that has the words "play tone" in it, or do you mean you hear a voice say "play tone"?
    In either case, it sounds like it's related to some app, as I mentioned before--so it would be software, not hardware.
    07-12-2014 11:57 PM
  5. Saravanan1003's Avatar
    Hi ,I have bought Moto G 2nd generation phone couple of months back, am frequently getting a popup icon as"play tone" with speaker symbol with a beep tone and vanishing ...this really irritating me badly...while phone is not in use also the popup is coming with beep tone n vanishing...I tried factory reset couple of time n no use of it.. I have uninstalled all apps but still I am facing the issue..this occurs even am in call...please help me out or share ur ideas to stop this...thanx in advance....when I searched in Google I got the only clue is this...pls help me.
    12-15-2014 01:21 PM
  6. Rukbat's Avatar
    Start the phone in safe mode. If it stops, it's one of the apps you installed. If not, it's a defective phone. If it's only a couple of months ole it's still under warranty. Back up everything, because they'll either replace the motherboard or the phone, and you'll lose all your installed apps and all your date in either case.
    12-16-2014 12:41 AM
  1. Samsung S4 issue with Hangouts
    Last Post: 02-26-2015, 07:00 PM
  2. Google Play Edition Power Saver?
    By muzia in forum Google Play edition HTC One M8
    Last Post: 10-23-2014, 06:26 PM
  3. Google play keeps popping up
    By Unregistered in forum Ask a Question
    Last Post: 07-09-2014, 10:53 AM
  4. Setting up new S4 Zoom- Play Store refusing to work???
    Last Post: 07-09-2014, 08:57 AM
  5. Gear Live / Multiple Issues - Questions
    By idealmuzik in forum Ask a Question
    Last Post: 07-09-2014, 07:49 AM
