+ Reply
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By RumoredNow
  • 1 Post By nitu12345
    AC Question
    AC Question's Avatar
    Guest
    Exclamation micromax canvas A120 colours battery stuck at 99%
    hello i have recently bought micromax canvas A120 colours from flipkart but from the first day i am facing battery issue.
    Micromax canvas a120 battery stuck at 99% and i have tried every possible way but its still at 99%. When I switch off the plug it shows 100% but with continuous charging it never goes to 100%
    plz help
    Thankyou
  2. #2
    Default Re: micromax canvas A120 colours battery stuck at 99%
    Does it always say 99% even with use? Or does the charge reporting go down normally when you use the phone?
    If it is just off 1% when topped off, but otherwise works normally, I would not sweat it. Probably set up in the battery app to report that way for some reason. You could try a battery pull and see if that helps...
    B. Diddy likes this.
  3. #3
    Quote Originally Posted by RumoredNow View Post
    its working fine
    but i never come to know when my phone gets charged completely since red led never goes to green all i have to check again and again
    and when i use app like Battery Doctor (Battery Saver) , they never alert me as phone battery stops charging after 99%
    shall i go for the replacement..?
    RumoredNow likes this.
  4. #4
    If it is anything wrong (and no alert for completed charge makes it sound that way), then it would be the chip in the battery.
    Maybe try a replacement battery first and if that doesn't solve it, keep the new (spare) battery and get your warranty on...
    IDK if it is relevant... On my Windows Phone, Battery will not display on Glance Screen or Lock Screen at 100%, but will at all other times. I have a battery minder app that lets me mark "full" as 99% among the options so that it will show on Lock & Glance... I'm wondering if you have a setting somewhere... Although I do still get notified of full charge status even though it says 99%...
  5. #5
    Hello! I bought a micromax canvas 2.2 two days back. and as the showroom guy said, I charged it for 8 hours for the first time. that's when I saw the green light when charging. even I face the same issue it gets stuck at 99%. and I have observed one more thing. it reaches till 99 very fast. and if u plug out the charger soon it reaches 99, it discharges fast. and if u keep the phone to charge for 1 hr in 99% it discharges slowly. so I concluded it charges slowly after 99, to maybe increase the battery life. I loved micromax. it's really good.
    I am not sure about my conclusion. It maybe true or it maybe a issue. Try asking showroom or customer care guys.
    Thank you.
    Regards
    Mohith.
  1. Why do so many apps start at boot?
    By FlareStorm in forum General News & Discussion
    Last Post: 07-04-2016, 11:07 AM
  2. Why does my phone "stay awake" all night long killing battery?
    By Randy Shaw in forum Samsung Galaxy S5
    Last Post: 08-03-2014, 01:08 PM
  3. Higher capacity battery for Tab 3 7.0"?
    By Galane in forum Samsung Galaxy Tab 3
    Last Post: 07-21-2014, 01:42 PM
  4. AT&T Price Adjustment Given Verizon's $99?
    Last Post: 07-10-2014, 08:01 AM
