1. dayzzz's Avatar
    Hello everyone. The tablet that i have is cheap and has 0 % online support, its still new model. Anyway the battery that it uses is 3.7 v and has 2300 mah. Is that too small for a 7" screen ? After unpluging charger, the battery immediately drops to 98% then few moments later it just continues to drop and after 1-2 hours the battery is dead. Whatever you do battery just dies that fast. Only stand by mode doesnt waste battery. I tryed battery doctor, clean master and nothing got improved. I turned off anything, screen brightes is the lowest possible. What should i do. Is it good idea to buy some 5000 mah battery of ebay ? Thanks. The tablet is wondermedia tpc 7152.
    07-11-2014 04:44 PM
  2. RumoredNow's Avatar
    Uh yup... That is a pretty small battery capacity for a 7" tablet. Also sounds like the battery might be bad for such rapid drain.
    I'd try a new, extended capacity battery for the device if you can find one.
    07-11-2014 04:56 PM
  3. dayzzz's Avatar
    Thanks for the answer. Another strange thing is that if the battery drains even faster ( playing games etc...) and after that you leave device in stand by mode, the battery will will go UP from 10% to even 90+% in 8 hours which was really strange to see because none device that i had did that.
    07-11-2014 05:10 PM
  4. RumoredNow's Avatar
    Yeah... The chip in your battery is definitely borked.
    07-11-2014 05:18 PM
  1. How do I do stuff when the call is on speaker?
    By NeatoTorpedo in forum HTC One Mini
    Last Post: 07-24-2014, 06:07 AM
  2. Battery life
    By Google_Superuser in forum Google Nexus 5
    Last Post: 07-12-2014, 10:03 AM
  3. Replies: 3
    Last Post: 07-11-2014, 11:57 PM
  4. Phone won't turn on!
    Last Post: 07-11-2014, 04:46 PM
  5. Nexus 7 2013- is it still a good tablet to buy now?
    By gymwarner in forum Google Nexus 7 Tablet (2013)
    Last Post: 07-11-2014, 04:17 PM
