+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Unhappy Lenovo P780 Charging problem
    Hi I have a lenovo p780 that can only charge when i press an area near it on the screen. I dropped the phone from 3 feet one day and and since it will not charge properly.. I took the phone into a repair shop that replaced the charging port and still same problem. There is a language barrier in the country I am in and the locals. I took it into the lenovo service center and had a problem there that they wouldnt fix it since it was bought in another country.
    The only way to charge the phone is to to plug it in and leave a gallon water jug on top on the phone for the weight to put pressure on the screen and it charges. Any help would be greatly appreciated!
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Lenovo P780 Charging problem
    Welcome to Android Central! Did you show the repair shop how it only charges if you press that area? Did they replace the port knowing that was a problem? If they weren't aware of that bit of information, they might not have looked for the specific cause of that loose connection.
  1. Replies: 55
    Last Post: 10-28-2016, 11:45 PM
  2. Problems (or not?) with my LG G3....
    By DudeThatsErin in forum LG G3
    Last Post: 08-08-2014, 02:14 AM
  3. samsung precedent wont charge
    Last Post: 07-11-2014, 11:22 PM
  4. note 3 s pen problem
    Last Post: 07-11-2014, 10:16 PM
  5. Please help!!!! My s3 wont turn on or charge!!!
    By Chris Wall in forum Ask a Question
    Last Post: 07-11-2014, 06:43 PM
