1. AC Question's Avatar
    Hi I have had my Samsung Galaxy S3 for over a year now, and the battery has been decent until now. It will be at 100% and drop considerably even though I am not on it. I always close all my apps down and the screen is always on the lowest setting and power saving is on constantly.
    Last night is went from 86% to 20% in 3 hours, with no use and then went from 20% to 1% within 10 minutes, with little use. I then turned it off and when I turned it back on it said it was 57% and proceeded to freeze on me and refuse to do anything. I took the battery out and put it back in and it said it had 0% battery.
    I am charging it right now and it went from 1% to 70% within less than ten minutes of charging, which is ridiculous. I have anther battery, a non genuine one in the post but I wondering if this one can be saved? Or if I can do anything to help it stay charged longer? I daren't use it because it drains so fast!
    07-12-2014 11:11 AM
  2. jmagid51's Avatar
    Seems like the battery is gone through its useful life. Time for a new battery.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
    07-12-2014 11:35 AM
  1. serious problem HELP PLEASE
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 07-29-2015, 03:55 PM
  2. unable to record call mini s3
    By Vijay Bangari in forum Ask a Question
    Last Post: 03-30-2015, 01:53 AM
  3. Samsung mini s3
    By Unregistered in forum Ask a Question
    Last Post: 03-04-2015, 10:04 PM
  4. samsung centura email set up
    Last Post: 07-13-2014, 01:43 AM
  5. Problem while calling over headphone
    By MetalxAssassinx in forum HTC One M8
    Last Post: 07-12-2014, 09:47 AM
