+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Unhappy galaxy s5 cant read my sd card after being in water
    well i tried my galaxy s5 in the pool and he was completly sealed by the panel and the charging panel , and then after a few hours he didnt readed the micro sd card .
    it even dont see that there is an sd card , nothing at all !
    i used the sd card and it worked perfectly .
    i tried putting my sd card on my brothers galaxy s5 and it worked completly normal , i tried removing the battery , factory reset , cleaning it with hair fan , nothing worked ....
    please help its very important !
  2. #2
    Default Re: galaxy s5 cant read my sd card after being in water
    How long was it in the water?
  3. #3
    Quote Originally Posted by AC Question View Post
    Why the hell would you do that for?
  4. #4
    Because Uncle Sammy tells them it is waterproof.
  5. #5
    I have no idea how much time , something like 10 minutes ...
    Anyways can someone help me fix this issue ?
  6. #6
    Quote Originally Posted by Nbhran3 View Post
    I would think if the card is fine maybe wait 5 days. Also try the standard procedure for wet phones, though it's functioning mostly ok, of keeping it in a sealed container of uncooled rice for 12-24 hours. It may start to work ok. There may be corrosion im the sd slot. Then if it doesn't work fry for a warranty claim. How you relate the story of it getting wet with the ports sealed is down to you, but I would avoid saying 10 minutes. I think Samsung claim it is water resistant.
    Also consider a new card.
    Sent from my SM-N9005 using Tapatalk Pro
  1. Droid Razr deletes read emails
    Last Post: 03-31-2015, 01:45 AM
  2. SD card question
    By thatguy97 in forum Android 4.4 KitKat
    Last Post: 08-08-2014, 10:15 PM
  3. All cards UI vs icons
    By blackguard in forum General News & Discussion
    Last Post: 07-21-2014, 09:13 AM
  4. transferrinig pictures from my samsung galaxy 3 to my laptop
    Last Post: 07-12-2014, 07:25 PM
  5. Samsung Galaxy 5 battery
    Last Post: 07-12-2014, 07:08 PM
