+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default wifi problem
    how do I fix my Wi-Fi when it says authentication problem.
  2. #2
    Evilnut's Avatar
    Posts
    Global Posts
    747 Global Posts
    Carrier
    Stock
    Default Re: wifi problem
    Very vague question.
    Fix your router? Fix your phone? Fix your tablet? Is this device the only one on your network with a problem? What manufacturer/model number? Does it work on other networks, did it ever work on yours, what wireless settings are on your router & device......
    Posted via a beautiful Ebony backed Moto X or the amazing Nexus 10 using the totally awesome Android Central App
  3. #3
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Quote Originally Posted by AC Question View Post
    It means that you might have typed the password the password wrong. It could also be a problem with your router security. Have you tried temporarily disabling the security (assuming your router has it enabled) and see if the device will connect then?
  1. HTC one X port problem
    By ragouz in forum Ask a Question
    Last Post: 03-30-2015, 02:50 AM
  2. WIFI won't stay turned on. Just turns back off again
    By stevish in forum T-Mobile Samsung Exhibit 2 4G
    Last Post: 07-19-2014, 12:00 PM
  3. HTC One M8 (mms sending and receiving problems)
    By matgon5 in forum HTC One M8
    Last Post: 07-12-2014, 10:19 PM
  4. Problem with nova folders
    By lsutigers03 in forum LG G3
    Last Post: 07-12-2014, 04:40 PM
  5. problem with my lock screen
    Last Post: 07-12-2014, 04:33 PM
