Android Maxtouuch Smart tab problem
A
AlexE123
I recently changed my visual settings to 1080p on my Android Maxtouuch Smart tab which runs android 2.3 operating system every time i turn on my device I can see the android and Maxtouuch logo and also a loading bar showing my device is starting up but after that I hear a pop and the screen goes completely black and I cannot access any thing on my device the screen just stays black please help thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Welcome to Android Central! Does your tablet actually have 1080p resolution? It seems unlikely to me that a device running an outdated version of Android would have full HD resolution. Are you rooted? If your tablet really doesn't support 1080p and you try to force it, it will probably do bad things.
MarcosVo
