1. AC Question's Avatar
    My samsung s3 phone does not turn on using my battery,it turns on if i use my friend's s3 battery.Unable to charge, as the samsung guy says the charger port isnt working.Is it a problem with the battery or charger port?Unable to decide... Kindly help if someone faced the same issue
    07-14-2014 12:54 PM
  2. Naser Bandora's Avatar
    Try another charger and if it doesn't work the problem is the battery
    07-14-2014 01:08 PM
  1. samsung galaxy s2 bluetooth
    By juveman in forum Ask a Question
    Last Post: 09-06-2014, 01:47 AM
  2. Hancom office on Galaxy Tab S
    Last Post: 08-11-2014, 07:56 PM
  3. Phone is slow. Major lag
    By Dharma Jairam in forum Samsung Galaxy S5
    Last Post: 07-14-2014, 05:56 PM
  4. Disabled Gallery prior to 4.4.2 update- can't turn back on.
    By srvctec in forum Samsung Galaxy Note 2
    Last Post: 07-14-2014, 04:52 PM
  5. WIFI not in range (even though it is)
    Last Post: 07-14-2014, 02:04 PM
