Results 1 to 2 of 2
    Default Samsung GS3 Volume Buttons and Notification Light Not Working
    Hi,
    My volume buttons and notification light have stopped working. The rep at the Verizon store said they can't fix it and I should try a factory reset. I am a little leery of doing that. Seems like a lot of pain for what I think is a hardware problem. Does a rest sound like it would fix these issues?
  2. #2
    Default Re: Samsung GS3 Volume Buttons and Notification Light Not Working
    Try powering off, then booting into Recovery. If you're able to, then the volume button must work. Try wiping the cache partition. [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
  1. Spilled alcohol on Samsung s4 3 days ago, any chance of survival?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-15-2014, 09:30 AM
  2. How do I add a contact on my Samsung Galaxy Centura phone?
    Last Post: 07-15-2014, 07:36 AM
  3. Any update on Updates? 4.4.3/.4 and Android L
    By droidntn in forum Samsung Galaxy S4
    Last Post: 07-15-2014, 07:25 AM
  4. S Planner Dots and lines no brief description
    By Unregistered in forum Ask a Question
    Last Post: 07-15-2014, 06:54 AM
