Results 1 to 6 of 6
    Default Blue Led light won't turn off
    My Samsung Galaxy S4 has solid blue Led light on for 2 days already and it doesn't changes or turns off. I have tried to check everything and do several things in order to get it back to normal and my phone could react as before but there was no success. Any ideas what could be the problem and what I have to do?
  2. #2
    Default Re: Blue Led light won't turn off
    Have you got voice recorder switched on by mistake?
  3. #3
    ....And welcome to the forums!
    How can I check it?
    And thank you!
  5. #5
    I'm not familiar with the S4 but if you swipe down from the top of the screen, with two fingers in V formation rather than the single-finger swipe down, details will be revealed. If it is Voice Recorder, you'll be able to switch off from there. Of course you could also open the voice recorder app which I imagine you must have somewhere, but swipe-down just to switch off is quicker.
    Of course it may not be that. Re-posting the query in the Samsung Galaxy S4 forum would put you in touch with members with direct knowledge of the phone.
    Unfortunately I could not find that Voice Recorder is on. Ok, I have reposed the issue. Hope I will get some answer. But thank you anyway.
  1. Asus tablet (Android 4.3) won't save/recognize PDF files
    By charlie98403 in forum Ask a Question
    Last Post: 07-17-2014, 12:32 AM
  2. Aol email won't sync
    Last Post: 07-16-2014, 05:35 PM
  3. lg g3 doesn't turn on :(
    Last Post: 07-16-2014, 02:46 PM
  4. my phone not turned on
    Last Post: 07-16-2014, 12:53 PM
  5. My Cellular Internet Won't Work?
    By OliviaHubbard in forum US Cellular Galaxy S3
    Last Post: 07-16-2014, 09:48 AM
