1. AC Question's Avatar
    most of the time I'm listening to a podcast or spotify and after downloading a new podcast or just randomly switching from bluetooth to speaker or back to headphones the sound will just stop working. The rest of the phone will work but the sound won't. I've playing it through the built in speaker and still nothing. Restarting the phone will usually work but its really annoying to do this three to four times a day. Has anyone else encountered this problem and have some way to fix it.
    07-17-2014 05:51 PM
  2. badidea's Avatar
    It has also been happening when it goes from vibrate to sound when using the volume keys
    07-17-2014 05:54 PM
  3. OreoNutz's Avatar
    Has anybody figured this out? It happens at least 3 times a day with my Optimus G Pro and it's annoying. Oddly, sometimes I can fix it by just opening my camera app, but sometimes the only thing I can do to fix it is restart the phone, and it is ANNOYING! PLEASE, if anyone has found a solution to this please post it. THANK YOU!
    10-16-2014 10:05 PM
  4. Golfdriver97's Avatar
    Have you tried a reset?
    10-16-2014 11:11 PM
  5. sharpy123's Avatar
    10-09-2015 01:53 PM
  6. sharpy123's Avatar
    Whenever I'm listening to something, it doesn'ttater what it is, the slightest little bump will cause the audio to just cut out, the song will still be playing but there will be no sound at all, the only that I've figured out how to get it back is to restart the phone and it happens every minute it seems like and it's getting really annoying! I couldn't even put it back in my otterbox without the audio cutting out! If anyone figures this out please tell me!!!!
    10-09-2015 01:58 PM
  1. No more Android phones for you.
    By rastergrafx in forum Nokia X
    Last Post: 10-03-2014, 01:32 PM
  2. disable charge complete notification sound
    By preternatural in forum LG G3
    Last Post: 08-23-2014, 11:16 AM
  3. samsung galaxy mini
    Last Post: 07-17-2014, 05:49 PM
  4. chromecast sound issues
    Last Post: 07-17-2014, 05:44 PM
  5. Problems with 2013 outlook email sync with Galaxy S5
    Last Post: 07-17-2014, 04:40 PM
