+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Angry lost battery and now will not turn on
    my samsung galaxy s3 mini lost charge and when i put it on charge it will not charge/turn on at all. ive tried trouble shooting, hard reset, different sockets/plugs/chargers, taken the battery out for a few minutes and placed it back inside the phone, and none work. anyone know how to fix this?
  2. #2
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Default Re: lost battery and now will not turn on
    Quote Originally Posted by AC Question View Post
    Sounds like your battery is very dead. Could be because the battery itself has gone to battery heaven. Or because you screwed up the charger cable's micro-USB connection where it goes into the phone, so that it doesn't make proper contact and can't charge. You can check both by putting another, working and charged, battery in your phone. If it works there is nothing wrong with your phone. And if you stick your 'old' battery into another S3 and it turns out to work (after charging) then there's nothing wrong with the battery either. Which leaves the charger as the culprit. With most likely a bent micro-USB connector.
    In that case: replace.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,694 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    I think it's the battery as well. Try getting a replacement and let it fully charge before powering on.
  1. what does this icon mean and how do I get rid of it?
    By ImpalerPLM in forum Sony Xperia Z2
    Last Post: 07-22-2014, 04:19 AM
  2. Slow Wi-Fi on M8 with new fibre optic broadband (70mb)
    By diegotristanUK in forum HTC One M8
    Last Post: 07-18-2014, 11:27 AM
  3. will a different model screen work on a samsung S5?
    Last Post: 07-18-2014, 05:57 AM
