1. AC Question's Avatar
    My Samsung Note recently start actting up my phone frozed and i turnt it off then when i try turn it on it vibrates and won't turn on but when i take out my battery and put it back in its shows the samsung loading screen and then black screen (Turns off) whats going on?
    07-18-2014 04:29 PM
  2. SpookDroid's Avatar
    It might be something wrong with the OS or it could be something worse. Let's rule out software, first.
    With the phone off, press and hold the power, home, and volume down buttons for about 10 seconds. By this time your phone should have booted up in Recovery Mode.
    If it did, chances are your hardware is not dead yet. If it didn't, it's not looking so good for your phone. But now that it did, try rebooting (you should see the option there, move around with the volume rocker, select with the power button). Did it boot up correctly? No? Try booting into Recovery Mode again. Now select "Clear Cache" or "Clear Dalvik Cache" (Can't remember how it shows up). And then reboot. Did it work?
    Still no? (Curses!). Here you have two options. Either take it to a service center or try to factory reset it yourself. While the latter would bring your phone to a 'factory state' and would, in theory, fix any OS issues, it does have the side effect of wiping all of your data with it. That means pictures, documents, apps...everything. So try to back up your phone first before doing this.
    07-18-2014 05:01 PM
  1. Recurring "system update" on Samsung Galaxy s5
    Last Post: 12-16-2014, 05:15 PM
  2. should I get a screen protector for my Samsung galaxy s5
    By Unregistered in forum Ask a Question
    Last Post: 07-18-2014, 04:43 PM
  3. SNote does not sync across all devices on Note Pro 12.2
    Last Post: 07-18-2014, 04:14 PM
  4. sumsung galaxy
    Last Post: 07-18-2014, 04:12 PM
  5. Galaxy s3 problems
    By dap111 in forum Ask a Question
    Last Post: 07-18-2014, 04:09 PM
