+ Reply
Results 1 to 2 of 2
    Unregistered
    Unregistered's Avatar
    Guest
    Default battery charging problem
    yesterday my galaxy fit was showing charging even when i unplugged then becomes normal after some battery is used up.
    but now it doesn't shows charging or use connected but it charges.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,015 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery charging problem
    Does it still happen after a reboot? If so, try wiping the cache partition. Follow the steps in the video, but instead of selecting Wipe Data/Factory Reset, be sure to select Wipe Cache Partition.
  1. Samsung Galaxy Note 10.1 No Charging!!
    By Makenzie_Ann in forum Ask a Question
    Last Post: 08-21-2014, 12:33 PM
  2. Battery Drain
    By Shawn0813 in forum Samsung Galaxy S5
    Last Post: 07-23-2014, 05:08 PM
  3. doesn't charge to 100%
    By Dperks17 in forum Samsung Gear Live
    Last Post: 07-21-2014, 08:40 PM
  4. Problems with tablet
    Last Post: 07-19-2014, 01:34 AM
  5. Samsung Galaxy Note 10.1 No Charging!!
    Last Post: 07-19-2014, 01:16 AM
