S4 Battery drain? Help
AndrewKama
4
My phone says my screen is using around 40% and i turned down all the things it told me to turn down and it still stays at 40% please help.
Sent from my SCH-I545 using AC Forums mobile app
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,274
4,385
113
Screen will almost always use the most battery. Turning down the brightness won't immediately lower that 40% figure, because that's over the span of that particular charge cycle. You would have to compare it with almost identical usage starting from 100%, but with the brightness turned down, to be able to compare.
gkapidis
