1. AndrewKama's Avatar
    My phone says my screen is using around 40% and i turned down all the things it told me to turn down and it still stays at 40% please help.
    Sent from my SCH-I545 using AC Forums mobile app
    07-20-2014 09:58 PM
  2. B. Diddy's Avatar
    Screen will almost always use the most battery. Turning down the brightness won't immediately lower that 40% figure, because that's over the span of that particular charge cycle. You would have to compare it with almost identical usage starting from 100%, but with the brightness turned down, to be able to compare.
    07-20-2014 10:08 PM
  1. S4 battery question
    By AndrewKama in forum Ask a Question
    Last Post: 07-21-2014, 01:55 AM
  2. Battery problem at 0%
    By trapmaster46 in forum Motorola Droid MAXX
    Last Post: 07-20-2014, 09:50 PM
  3. Need some help tablet locked up
    Last Post: 07-20-2014, 09:08 PM
  4. Replies: 1
    Last Post: 07-20-2014, 09:07 PM
  5. Samsung s4 and 2015 mazda
    By Kaainoa in forum Ask a Question
    Last Post: 07-20-2014, 08:57 PM
