1. AC Question's Avatar
    I just got my S4 a month ago. yesterday it got extremely hot and the battery drained 40% in 2 minutes. Can anyone help me?
    07-21-2014 05:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Has this behavior continued? The battery might be failing. Take it out, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is a bad sign--try a new battery.
    A corrupt SD card can also cause behavior like this. Unmount the card (in Settings>Storage), remove it, and reboot. You could try a different SD card, as long as you know that card is good.
    Screenshots of the battery stats would be good, if this happens again.
    07-21-2014 11:53 AM
  1. OnePlus One Battery Life
    By guinnkevinr in forum OnePlus One
    Last Post: 11-11-2014, 02:53 PM
  2. Battery drains much faster
    By Rupesh Mehta 1 in forum Ask a Question
    Last Post: 09-06-2014, 02:25 AM
  3. Random Restarts and Drained Battery
    Last Post: 07-21-2014, 04:36 AM
  4. S4 battery question
    By AndrewKama in forum Ask a Question
    Last Post: 07-21-2014, 01:55 AM
  5. S4 Battery drain? Help
    Last Post: 07-20-2014, 10:08 PM
