1. AC Question's Avatar
    My devise will not charge consistently. Sometimes when I plug in the charger the lightning bolt to indicate that it is charging does not appear. I believe that the charging port is loose since it has been nocked off of the night table while it was charging one or twice. Is this something that can be fixed or would it be better to get a new one and transfer all my data?
    07-21-2014 12:52 PM
  2. SpookDroid's Avatar
    If it's the USB port, it can definitely be replaced, and it's not expensive (for a Galaxy S4, at the Samsung Service Center it was around 20 bucks the last time I heard, and you can get it for less online, but you'd have to install it yourself, and that's an added risk).
    But before running off to change the port, check that your charger and cable are not to blame. Try a different USB cable, and if you're still having issues, try a different charger. I had a similar issue with my tablet and the problem was the cable; got it replaced, and voilá!, no more issues.
    07-21-2014 01:01 PM
  1. Replies: 4
    Last Post: 12-15-2014, 07:50 PM
  2. s4 black screen problem.......... again!
    Last Post: 09-04-2014, 09:47 PM
  3. wallpaper problems, driving me insane.
    By kmw3425 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 07-24-2014, 01:11 PM
  4. My htc rhyme won't charge
    Last Post: 07-21-2014, 12:09 PM
  5. Problem with Amazon Appstore after 4.4.4 update
    By Andy88488 in forum Motorola Droid MAXX
    Last Post: 07-21-2014, 11:57 AM
