1. AC Question's Avatar
    Don't know how I did it, but everything is flopped to what appears to be left hand mode on my Motorola Droid Maxx HD, Verizon, running 4.4.2. Anyone know how to flop it back?
    07-21-2014 03:19 PM
  2. N4Newbie's Avatar
    Try Settings -> Developer Options -> Force RTL layout direction
    07-21-2014 03:21 PM
  3. Toid's Avatar
    My phone is company issued, I don't have Developer Options in my Settings. Is there a backdoor method to get there?
    07-21-2014 03:44 PM
  4. Toid's Avatar
    Found the trick, settings, about phone, scroll to build number, tap 7 times. After the third tap a little dialog pops up saying you are almost there or something like that. This worked, my phone is back to right hand mode. Thanks!
    07-21-2014 04:28 PM
  5. N4Newbie's Avatar
    You're welcome; however that doesn't change the fact that something is a bit odd here. So far as I know the phone should be in "normal" mode until you enable Developer mode and then deliberately force RTL (Right to Left) mode by checking the option noted above.
    Just curious: was the option checked or unchecked when you first enabled developer mode?
    07-21-2014 05:49 PM
  1. "Server Error in '/' Application." I'm stumped.
    By Unregistered in forum Ask a Question
    Last Post: 01-12-2016, 04:57 AM
  2. contact ringtone in moto g
    Last Post: 03-03-2015, 10:54 PM
  3. How to remove addresses in Google Wallet
    Last Post: 09-07-2014, 02:23 AM
  4. What new features are there in MOTO G after android 4.4.4
    By Prakhar Mohan1 in forum Moto G (2013)
    Last Post: 07-21-2014, 04:25 PM
  5. Droid ultra only charges when turned off
    By jfd3 in forum Motorola Droid Ultra
    Last Post: 07-21-2014, 02:50 PM
