+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Angry Charging problem- new info
    Hey everyone. Heres the issue I had. Lenovo p780. Originally the red light stopped coming on and phone would not charge. Steps Ive taken already-
    1. I have replaced the charging port- Not the issue
    2. I have taken to service center- they refuse to fix saying it was licensed for china and not russia.
    3. I have been to 3 smaller centers and no one can fix it. (But they arent that smart here anyway)
    What I did that worked (for a week) was open it up and put electrical tape behind the port and the glass. Because it would charge when you apply pressure to the top portion of the screen. (I would use a gallon water jug on top to charge it before).
    Then it stopped charging again. I would open it up and have to move things around and it would start again. Then after a few days, that stopped working.
    Now I noticed the only way to get it to charge is to open it up, plug it in. (light is off). I remove the battery connector (light starts flashing rapidly). I reconnect the battery connecter and it starts charging again......
    Not sure how to go about fixing this and if thats the only issue. I cant afford a new phone for another month so until then I need to find a solution.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,882 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Charging problem- new info
    You should show an independent phone repair shop how you could get it to charge by applying that pressure. The technician might then have an idea of where to look for the problem.
