1. AC Question's Avatar
    Recently I took my phone to the pool to test the waterproof of it. Everything was sealed and the test was positive, no damage was done. At the time of this, my phone was on 1%, but I needed it on for at least fifteen more minutes, so I switched it to UPSM. I have done this before and got it to a charger before the battery died, but this time I was unable to do so. Now, my phone has been plugged in for about an hour now and still won't turn on. Is this possible water damage, or did UPSM suck the battery dry and I just need to keep it plugged in overnight before it turns on? Thanks for any help!
    07-23-2014 10:11 PM
  2. warn joe's Avatar
    Well, I was not going to test my s5 i.e. putting inside the water intentionally to see if everything work fine or not ! I can't say actually but I think there is some possible damage done by the water I don't think that UPSM has suck the battery dry even if its has 1 has to be get back on after 15min or ..... weird but I think you may need to take your device to the customer support.
    07-23-2014 11:59 PM
  1. Galaxy S 5 notifications
    Last Post: 12-16-2015, 04:38 AM
  2. Mission to Improve S5 Battery Life
    By slaskwroclaw18 in forum Samsung Galaxy S5
    Last Post: 07-24-2014, 09:35 PM
  3. Replies: 13
    Last Post: 07-24-2014, 05:33 PM
  4. Samsung Galaxy s4 mini: I can hear, they can't.
    Last Post: 07-24-2014, 12:49 AM
  5. Galaxy S4 doesn't connect to PC
    Last Post: 07-23-2014, 09:57 PM
