1. vivian6787's Avatar
    Hi, i own a sony xperia m running cm11. After flashing cm, my batery started draining very fast. The problem is, i flashed the franco kernel using cwm and now my phone wont boot!!! And the fast boot mode is also not working! Please help me guys, is there any way i could make my phone boot again?
    07-27-2014 01:23 AM
  2. wizzrah's Avatar
    Hello. If fastboot is working, try using your PC to flash the boot image of the ROM. Look inside the cm folder on your PC. A file called boot.img should be inside. Simply copy that file, paste it into your folder containing the adb and fastboot files you usually use, and then use CMD to flash the boot.img.
    The command should be 'fastboot flash boot boot.img'
    Sent from my One Xl using AC Forums mobile app
    07-27-2014 02:42 AM
  1. problem with M8 when using speakerphone
    By meatclown97 in forum HTC One M8
    Last Post: 12-10-2014, 05:09 PM
  2. REALLY weird thing happened today on my Moto X
    By jeffrok in forum General Help and How To
    Last Post: 07-30-2014, 04:05 PM
  3. candy crush crushed my htc one x
    Last Post: 07-27-2014, 01:08 AM
  4. my files / list by name not thumbnails / camera vs gallery
    By Unregistered in forum Ask a Question
    Last Post: 07-27-2014, 01:04 AM
  5. Deleting synced Facebook photos.. HELP!!!
    By Jen Lloyd in forum Samsung Galaxy S5
    Last Post: 07-26-2014, 11:46 PM
