+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Phone switches off and does not start until charger plugged in.
    I have been using Samsung Galaxy Grand (I9082) since over a year and now the phone switches off randomly (generally at 28% of battery remaining) and when i try to restart manually, it does not starts (and battery drops to 1 % ) until i plug in charger and within 2 minutes battery shows mre than 30% charged . I have been charging the mobile from some other nokia charger. The battery graph also shows red lines. Does this indicated the battery problem or phone.
    NOTE : I have done cache cleaning with fresh Android install after the problem started in order to trying to fix the problem.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,692 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Phone switches off and does not start until charger plugged in.
    Is the battery bulged? Easy way to tell, is place it on a flat smooth surface and try to spin it.
  1. Replies: 1
    Last Post: 01-24-2016, 03:02 PM
  2. galaxy tab pro 12.2 not playing videos on si.com
    By Unregistered in forum Ask a Question
    Last Post: 03-31-2015, 01:38 PM
  3. Replace OS on Android Phone
    Last Post: 07-27-2014, 08:46 PM
  4. Does Odin need root ?
    Last Post: 07-27-2014, 09:15 AM
